Old 03-18-2019, 09:58 PM   #9
Mike Rietow
Mike Rietow's Avatar
Liked 30 Times in 16 Posts
Default Re: Torque converter slippage
Originally Posted by Makinchips View Post
What percentage does an 8" a/sa or b/sa converter slip approx.
I'm considering upping the rear gear in my bracket car which runs low 10s presently but am unsure of the rpm gain from converter slip.
There is an equation. Need this info.
Tire size + observed roll out? + bias or radial?
Current gear
New gear
The current rpm and mph at the stripe.
It'll tell exactly what rpm you'll cross with the new gear , as well, as converter slip percentage with the current and new gear.
7x S/Pro 'Sunshine" http://ottm.store
https://youtu.be/I8QWEaqeFRw
Mike Rietow is offline   Reply With Quote
