Liked 128 Times in 50 Posts
How about the huge $1,500 check Skillman won?
Bobby Lundholm 3516 G/SA |
Liked 1,984 Times in 597 Posts
The Skillman will probably donate their winnings to a charity. They do a lot for their community.
Mike Pearson 2485 SS |
I'm sure they do but that's not the point. It's investing $150,000 in a car and winning $1,500.
Bobby Lundholm 3516 G/SA Last edited by Bobby Lundholm; 03-19-2019 at 09:28 AM. |
150k lmao!
Todd Greene |
Liked 154 Times in 37 Posts
This ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ^^^^^^^^^^^^^^^^^^^^^^^^
66W30POST |
Liked 55 Times in 14 Posts
Liked 53 Times in 20 Posts
That's even worse. I was basing my estimate off of buying the car, pulling the engine and trans to have them gone through.
#9 | |
new car $130,000 Build a showdown engine $40,000 Showdown Trans and convertor $15000 Update cage to 7.50 spec $9000 full racepack $8000 second set wheel tires $3500 Lighten car add weight to back $500 different third member $2500 Proper shifter $1000 Suspension $10,000 in car communication $1500 Assorted other things needed $3000 Spare parts $$$$$$$ Total at least $225000 You can do it for a bit less but you will not qualify and may not even at that cost either. And constant work needed after each event. And add in a trailer and Motor home you can add $250,000-$400,000 It is not a class for the average sportsman. |
Liked 684 Times in 289 Posts
JDM Engineering once posted on here, that one of his customers had 100K in the trans. I asked if he meant 10K, he said nope.
MJ |
