Is there a ci limit for ss A modified ? Seem most are small ci
354 cubes. Do the math. 2650 min. wt. /7.5 lbs.per cube.
Liked 5 Times in 2 Posts
I've never seen a maximum cubic inch in the rule book. The limit on cubic inch would probably be dictated by the maximum weight of the SFI chassis certification. I want to say the largest cubic inch I've seen used is 450 or so cubic inches. The reason for the smaller cubic inch engines is because most people want to be as close to the minimum weight as possible and also because most SS/AM cars are SB's as well.
Adriel Paradise, Paradise Racing Team Driver/Crew Chief(at least my dad claims me to be) B.S. Mechanical Engineering, University of Arkansas |
Liked 70 Times in 29 Posts
That's just the most you want to claim...right? LOL
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
So it would be ci x 7.50 lbs and at 440 ci I would have to weigh 3,300 lbs or would I still have to add weight ?
Thanks for the reply’s |
Liked 25 Times in 11 Posts
Your weight would be 3300 lbs if you are running a stick. Deduct 5% if you run an automatic which would make it 3135.
Tracy Robbins SS 9766 |
