Old 02-21-2019, 10:39 PM   #9
SSDiv6
Liked 1,579 Times in 582 Posts
Default Re: Can You Help Me Find This?
Bobby,
I have one of the timing belt setups.
Sometime ago I did the research for the replacement belt since the numbering system, as it is for bearings and seals, is an SAE specification.
There are industrial belts that will work as a replacement. Also, there are belts designed under the numbering system to work immersed in hot oil.
