Old 02-05-2019, 07:16 PM   #1
jlundy
Default Re: Want to run 9.90
Originally Posted by Lenny5160 View Post
If you want both of your shifts to happen by RPM, you can absolutely do that. No issue.
Thank you Lenny for the help.
I just purchased the Pro Cube with 3 timers and ZForce from K&R so I'll let the box shift it on time.
Jeff
jlundy is offline   Reply With Quote
Old 02-06-2019, 01:23 AM   #2
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Seems less than ideal, if I'm understanding it correctly. If you want the shifts to happen down track at wide open throttle, the time setting for your desired RPM will change every time you change your throttle stop time. You'd be better off using RPM as the shift trigger.
S/ST 51
S/C 53
Old 02-06-2019, 10:46 AM   #3
jlundy
As I mentioned in my first post, it's painfully obvious that I have no clue what I'm doing. That really is the main reason I joined this forum, to read and ask questions.
I guess I need to shift into 2nd on the stop then coming off the stop say 7000 rpm = time? shift into 3rd for the remainder of the run. Thought time was more consistent than RPM?
I thank you Lenny for taking the time to help this racer whom thought he'd have a go at electronics racing.
Old 02-06-2019, 11:22 AM   #4
Hacksaw
Liked 310 Times in 174 Posts
What about getting it to shift to high gear when your on the stop? Wouldn't that be the most consistent? Thinking you would need a little down track speed but your really fooling the car to think it has a PG trans.
Old 02-06-2019, 12:37 PM   #5
Lenny5160
Lenny5160's Avatar
How fast does the car run wide open? That will influence the options you have. As Hacksaw mentioned, you can go all the way to High gear while on the stop, but you probably want to be a full second quicker than the index (say a 8.90 or quicker car when trying to run 9.90) to pull that off. I get the feeling that your car isn't that quick.
I've never run a 3-speed, but here's what I think I would do in your situation. I'd launch the car hard, then put it on the throttle stop. Have your shifter hooked to a timer which would put the car in 2nd gear shortly after the throttle stop turns on. When the car goes wide open again, I'd either have some way to put the car in 3rd based on RPM or just shift it by hand at the desired RPM.
S/ST 51
S/C 53
Old 02-06-2019, 12:45 PM   #6
jlundy
To be honest I have no clue what it runs...........I run at altitude 4000ft. This is an all new combo 445ci SBF, C4 trans, 486 gears. 2260# with me in it.
Just fired the motor first time last Sunday while everyone was watching super bowl.
Old 02-06-2019, 02:09 PM   #7
pmrphil
Liked 348 Times in 152 Posts
Have you done the math regarding rear gear and tire size? As far as finish line RPM goes?
Phil Molski
PMR Performance
S/C 1623
Old 02-06-2019, 01:25 PM   #8
drgrcr1156
Liked 2 Times in 1 Post
I've never run a 3-speed, but here's what I think I would do in your situation. I'd launch the car hard, then put it on the throttle stop. Have your shifter hooked to a timer which would put the car in 2nd gear shortly after the throttle stop turns on. When the car goes wide open again, I'd either have some way to put the car in 3rd based on RPM or just shift it by hand at the desired RPM.[/QUOTE]
I run a 3 speed TH400 in 9.90 and this is how I have my shifts set.
drgrcr1156 is offline   Reply With Quote
Old 02-06-2019, 12:39 PM   #9
jlundy
That could work. 1, 2 shift........On stop, come off in high gear. What kind of shock to the converter would that be if any?
Old 02-06-2019, 03:13 PM   #10
Hacksaw
I think as long as you have some decent rpm and wheel speed on the stop the converter can handle it and recover quickly. Lots of PG racers do this now. Check with a doughnut maker and get there advice.
