Old 01-31-2019, 07:48 PM   #1
SSGT Mustang
Liked 204 Times in 54 Posts
Default Re: FS/XX - SS/AH In Comp ?
Originally Posted by Chuck Norton View Post
My statement may have been unclear but, to restate it more specifically, the thorough teardown of a Stock Eliminator car takes at least ten times as long as is required to P&G a Super Mod or a Street Roadster. All FS cars running in Comp will need to be thoroughly inspected and qualifiers should be subjected to a full teardown. Current practice with regard to teardown is that it happens only a few times per year under the best of circumstances and that's not enough to keep everyone within the fences.
A thorough teardown requires the engine out of the car and the oil pan off. Crankshafts should be inspected, tops of pistons will need to be inspected, cylinder head chambers and runners need to be poured, casting numbers on cylinder heads and camshaft lift need to be verified, blower specifications confirmed, and throttle bores measured. All that is just the tip of the iceberg for making sure that any Stocker is legal. Even a run-of-the-mill Stock teardown involves all those things and more minus the removal of the oil pan. If there is not even at least a remote possibility that these variables will be subjected to inspection it won't be long before the FS cars will be capable of running more than a second under the proposed index and the only thing separating them from a thinly disguised Pro Mod will be the tires. If they get a big tire... I don't think that the Honor System will suffice!
The sad part of it is that it's not happening all that much in Stock either.
The sadder part is that they're probably more likely to get torndown in comp.
SSGT Mustang is offline   Reply With Quote
Old 02-07-2019, 02:55 PM   #2
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Cool Re: FS/XX - SS/AH In Comp ?
Originally Posted by ssgt mustang View Post
the sad part of it is that it's not happening all that much in stock either.
or not get torn down at all !
