Old 01-28-2019, 11:14 AM   #11
Hacksaw
Liked 312 Times in 175 Posts
Default Re: Flaming River Steering Box in a 69 Camaro
Originally Posted by Brian Oakes View Post
Mike are you sure you used a vega pittman arm, Vega,s are straight one's, Camaro's have a dip in them.
Brian: I think the OEM Vega arm does have an offset and all the aftermarket ones are straight. ?????
Old 01-28-2019, 12:01 PM   #12
Mike Pearson
Mike Pearson's Avatar
Liked 1,944 Times in 585 Posts
Yes. I used the straight one. I needed to lower the drag link to clear the oil pan. The straight pittman arm gave enough clearance. I did have to lower the idler arm on the opposite side to match. Then a bump steer kit to lower the tie rod end at the spindle to correct that geometry. Worked out pretty nice.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
