Old 01-08-2019, 11:58 PM   #821
Nmbr1GMfan
Default Re: H-I-J '76 Nova re-fit.
Originally Posted by jims5600 View Post
Best of luck doing your testing. When we raced,I enjoyed dyno testing
as much as or more than actual racing. The last dyno session we had
was at FJ Smith's with our comp engine. Spent the better part of one
day there. A fond memory for sure.
Jimmy
Jimmy, I'll assume this will be the first of many Dyno outings I hope. First engine Dyno for me so I'm pretty excited. Should have it on tomorrow and make some pulls Thursday.
Todd Greene
Old 01-09-2019, 10:34 AM   #822
Alan Nyhus
Liked 799 Times in 236 Posts
Todd, an experienced dyno operator will be invaluable to you. They understand trends and can give insight as to what the engine 'wants'. We're lucky to have have access to two great dynos and smart, smart, operators: Matt Steen and Jason Verke at Victory Engines in Marshall Minnesota and Bob Sherwood's private dyno here in Sioux Falls, S.D. On the last session, I learned a lot about oils and fuels, for example. And QJets in particular have certain characteristics at high rpm that the BSFC can help identify.
If you've never dyno'd before, it can be a bit unnerving at first. When the brake loads the engine and the rpm's start to climb that first time....
All the best for an informative session. -Al
"That'll never work....."
Old 01-09-2019, 04:37 PM   #823
Nmbr1GMfan
AI, I know I'll be better informed at the end with much more to be learned later.
Todd Greene
Old 01-10-2019, 09:27 PM   #824
Nmbr1GMfan
Aaaand we broke it.
Todd Greene
Old 01-10-2019, 09:30 PM   #825
Alan Nyhus
Well, on a good note...you found why you were down on power.
Everything still inside the block?
Old 01-10-2019, 09:34 PM   #826
Nmbr1GMfan
Yes, still intact and idles fine. Destroyed some bearings thats for sure.
Todd Greene
Old 01-11-2019, 12:06 PM   #827
Dave Gantz
Liked 251 Times in 125 Posts
Ouch. Sorry to see this.
Your first post in this thread says, "It's not really a build". I think a new motor makes it officially a build.
Look at it this way; just about the whole car is new. Now you'll have a motor to match.
Good luck, hope it's not too "painful".
Old 01-11-2019, 01:39 PM   #828
Nmbr1GMfan
Dave, well, I don't think it will be too terrible. It does still turn over remarkably well with what seems to be some excessive end play, hope we can save the crank and rods. Springs on the heads look to be set up poorly so I'm sure valvetrain will be dealt with now too.
Todd Greene
Old 01-11-2019, 02:44 PM   #829
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Todd,
Sorry to hear the news. Just curious, did you do a leakdown on the engine prior to any passes upon purchasing? Have you checked leakdown since the dyno? Not that it matters now, but that is another logged item after every race that I perform on mine. Hopefully it is not too bad to get it fixed.
Good luck.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 01-11-2019, 03:15 PM   #830
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
That looks pretty minor compared to what some have done. Glad it was caught before " catastrophic failure" occurred. Please keep us in the loop on your findings and the rebuild.
Tim H is online now   Reply With Quote
