Old 12-30-2018, 02:53 PM   #2
jmcarter
jmcarter's Avatar
Liked 3,184 Times in 973 Posts
Default Re: I just need a couple inches.....
Have you looked at the available shanks that would move the actual ball aft by 2 inches? Not all the shanks have the same dimension from hitch pin hole to the ball...and course different brand weight distribution hitches may dictate which shank you can use. Know the SuperHitch brand with truss type extensions are way too expensive but offer even more..
Ive used etrailer.com for unique towing options.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
