Old 12-25-2018, 03:33 PM   #1
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Default Re: The best "Dime Rocket" combos!
I suppose, seeing it's Christmas, I ought to be more charitable.
Okay, you've got the car and want to race it. Better than sitting behind a keyboard all the time. I know that story.
Anyway, so what are your plans for this thing? Where will you test it at a reasonable altitude? Kearney is 300 miles, right?
How about the clutch? Trans and shifter? Rear end?
The reason I ask is because Stick shift / Dime rocket doesn't necessarily go together. You know , like jumbo shrimp? Rap music?
Kearney is in the 350 range, Great Bend I believe is a bit farther, bandimere is around 65-70 miles and an altitude track (but you guys know that) the rest needs to be determined but it won't be a high-dollar setup....retirement doesn't pay all THAT well...
I DO have a 3.73 TG out of a 78 amx and a 3.44 1st st-10 that could be put into use...I don't know what the rev capabilities are on a 199 (that'll put it in V/S or V/SA( if I wanted to run Lane Weber)...232/258? I don't know either...shifter? i'm using a hurst supershifter (street one, not the reverse lockout type)..
Old 12-26-2018, 10:58 PM   #2
joe huestis
Liked 411 Times in 114 Posts
What started out as a dime rocket but no longer is, back in 2015, I undertook building an '81 Camaro for U/SA with the 267-2V combo. Finally made it to the track last March and have managed to shave off .52 seconds off my ET after only 32 passes. Had loads of fun this year back racing with the CCRA after a 3 year hiatus. Special Kudos for the help from Doug Hobgood, Doug Smith and Mike Moller. Also for Billy's advice in making this combo work. All of his coaching has paid big dividends. This winter a metric 200 goes in the car after using my trusty Turbo 350 this past season from my Monza. Looking forward to some better results in '19.
Joe Huestis
Youngsville, NC
Old 12-29-2018, 09:40 PM   #3
jmantle
Liked 172 Times in 81 Posts
Tom, find an old Comet or Maverick, much easier way to go.
77 / 79 AMC 258 with a 2 barrel, 150 HP
Some of the 70,s 302 2 barrel Fords are as low as 137 HP last time I checked.
I was fortunate, my car is heavy enough to hide in V.
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
Old 12-30-2018, 04:11 PM   #4
Billy Nees
Liked 7,891 Times in 1,753 Posts
Oh come on Jim! We need more diversity!
Billy Nees 1188 STK, SS
