Old 12-12-2018, 07:54 PM   #1
Nmbr1GMfan
Liked 1,954 Times in 491 Posts
Default Re: H-I-J '76 Nova re-fit.
Originally Posted by Sean Marconette View Post
Hi Todd,
What gear is she doing a burnout in, it looks like 2nd? Have you tried 3rd gear, as that will have a higher wheel speed and require a lower engine RPM to do so.
Also what are your thoughts on the wheelie bar?
Again very cool build!
Sean
Yes Sean 2nd gear, I agree 3rd would be a better option but I think shes too inexperienced and would stress the trans too much, we'll work into that. The bar is of high quality and is real nice, Ken said he runs them about 10" off the ground but at that height it would easily get pushed into the bumper on a hard launch so I set it at maybe 8", well I didn't realize just how much the axle wraps up with these leafs so even on a soft launch it will bounce the wheel off the track. I'm going to call Caltrac and see if it's normal or I have to change something in the suspension.
Todd Greene
Old 12-12-2018, 08:09 PM   #2
TOSTO RACING
TOSTO RACING's Avatar
Liked 639 Times in 182 Posts
Todd save the call to cal trac. I chose not to weld my bottom bar on the wheelie bar and just use a bolt to set height (I figured I would weld it once I made a few runs so I can set height perfect) and mine hit the ground so hard it broke the bolt on a pass leaving the bar dragging down the track !!! I set my bar 13 inches on these runs. Now its 15 inches off the ground to hopefully not have it hit on the leave.
I think its a stick car thing as far as axle movement maybe a good shock will stabalize it a bit more idk.
5664 GHI/SA
1985 CAMARO RED H/SA
1985 CAMARO BLUE I/SA
TOSTO RACING is offline   Reply With Quote
Old 12-12-2018, 09:05 PM   #3
Nmbr1GMfan
I did the same thing, bolted it to get it right then I'll weld. Crazy how much it moves. I have a new set of DA shocks on the way to replace the Caltrac shocks.
Todd Greene
Old 12-13-2018, 12:19 AM   #4
J&S Racing
Liked 319 Times in 82 Posts
Not sure if it was shenanigans but when ken found my car was a stick he sold me on a bigger diameter bar. It’s crazy how violent the bars move shifting a stick. ( could see it in your first vid )
When I recently ordered my rear shocks Marty had me measure from the mounting spot to the cal tracs with the rear end hanging. He mentioned some stick guys having issues with to short of rear shock travel.
Old 12-13-2018, 09:43 AM   #5
TOSTO RACING
I also got the bigger bar from Ken because of the stick . I think the shock deal is the ticket in fixing this . Actually my bottom bar is slightly bent from smacking the ground also . What's weird is I don't remember the dual bars ever smacking the ground like this and it shouldn't matter they both bolt to the housing ?? I dont have a real good shock yet just a single adjustable so we will see .
5664 GHI/SA
Old 12-13-2018, 09:57 AM   #6
Nmbr1GMfan
When I purchased the car the shocks were full loose so I put them back the same way, I can see where a stiffer shock setting would calm it down a bit.
Todd Greene
Old 12-13-2018, 11:55 AM   #7
Dwight Southerland
Dwight Southerland's Avatar
Liked 772 Times in 192 Posts
Before good shocks were available, road race or dirt track 50/50 shocks were the answer. Very stiff.
Old 12-13-2018, 09:55 AM   #8
Nmbr1GMfan
I could definately see a real traction issue if the shocks were to bottom out. I noticed a puddle in the trailer and one shock was all wet so it must be time. I ordered QA-1 shocks, not the best but hopefully they'll be up to the task.
Todd Greene
