Old 11-19-2018, 11:52 AM   #1
Jeff Lane
Liked 12 Times in 3 Posts
Default Hancock & Lane Parts Sale
1 Set new 1.650 titanium valve springs ($1000 new) - $350
2 Carbon Hoods for Chevrolet Cobalt with Carbon Hood-Scoops - $800 / each
15 sets aluminum SBC connecting rods 5.380 – 5.580 (15 – 40 runs per set) - $200 set
10 sets used great condition Casidium coated piston pins .866 - .927 many lengths available - $100 set
15 sets used Titanium valves different lengths and head diameter. Perfect condition - $200 set of 8
8 sets used Titanium Victory retainers 10 degree for 1.500 spring size - $100 set of 16
10 sets used titanium Victory keepers 10 degree for beadlock valves 5/16 and 7mm - $50 set of 16
20 camshafts 50mm, 55mm, clamshell for SBC Wedge, SB-2 and Splayed valve engines. Call for specs.
Autometer Sport-Comp Playback Tach - $175
Book carb: 750 cfm for comp eliminator - make offer
Book carb: 850 cfm for comp eliminator - make offer
Jesel SBC .875 Drop in lifters SB-2 perfect shape - $500
MSD Front Drive Distributor complete - $375 FOR AURORA BLOCK
MSD chips 3000 – 10,600 RPM - $5.00 each
Simpson 5-point harness out of date SFI perfect shape - $100 set
Simpson coats, pants, neck collars (used) - make offer
9" Ford Richmond lightened gear sets: 5.28, 5.67, 6.33 - $200 each
9.5" 5.83 Ford Gleason lightened, coated and cryoed gear set - $800 / SOLD
BRAKES:
· 4 – 4 Piston STRANGE Front & Rear aluminum brake system with calipers, rotors, hubs and brackets B4154C - $1000
· Mark Williams front brakes, hubs (ceramic), calipers, pads, for Cobalt; used - $600
· Lamb rear brake system with, hats, rotors, pads; like new - $600
COMPUTER SYSTEMS:
· RPM Performance Products DL10 Computer with wire harness, sensors, and Dayton WEGO lllD System - $700
· Tons of Racepak parts and accessories (Collars, pickups, transducers, sensors, Cables, etc. Call for pricing
CONVERTERS:
· 2 - 7” A-1 / Schneider Steel Comp Eliminator Converters - $600 each / SOLD
· 2 - 9” ATI Stock Eliminator Converters - $400 each / 1 SOLD
TRANSMISSIONS: All fresh and can make many gear ratio combinations:
· 1 Pro Trans / Chrysler case with GM adapter with all light weight and billet parts 2:25 / 1:51 - $4400
· 1 Pro Trans / Chrysler case with GM adapter with all light weight and billet parts. 2:32 / 1:51 - $4400 / SOLD
· 1 Pro Trans / Chrysler case with GM adapter with all light weight and billet parts. 2:45/ 1:51 with Griner Valve Body - $4800
· 1 Metric 200 Transmission Automatic 1,2 shift with external adjustment – all aluminum and billet parts throughout 2:92, just updated to 1,2 shift with only 12 runs on it - $3000
· 1 Metric 200 Transmission Automatic 1,2 shift with external adjustment – aluminum drums 2:75, just updated to 1,2 shift with 0 runs on it - $2400 / SOLD
TIRES:
· Hoosiers BIAS 17.0 / 36.0 – 16 #C2055 ; 1 run - $500
· Mickey Thompson Drag Slick 14.5 / 32.0 – 15 #30751 ; 1 run - $450
· Mickey Thompson 32.0 / 14.0R – 15 #11808 ; used - $100
· Mickey Thompson 33.0 / 14.5R – 15 ; used - $100
· Goodyear Radials 30.0 / 9.0 – 15 ; used - $100
· Hoosier Drag Slick 9.0 / 30.0R – 15 #18212 ; NEW - $400
FRONT TIRES:
· 2 sets of Mickey Thompson 25.0 / 4.5 – 15; great condition - $100
· 1 set of Moroso Drag Special 5.50 – 15 4PR; NEW - $125
· 2 sets of Hoosier Drag Fronts 28.0 / 4.5 – 15; NEW - $125 SOLD
Jeff Lane
Hancock and Lane Racing
206-818-1804
hancockandlane@yahoo.com
Last edited by Jeff Lane; 11-21-2018 at 12:29 PM. Reason: Adding SOLD items to list
Jeff Lane is offline   Reply With Quote
Old 11-19-2018, 01:24 PM   #2
Glenn Briglio
Glenn Briglio's Avatar
Liked 986 Times in 314 Posts
Default Re: Hancock & Lane Parts Sale
Pm sent
Glenn Briglio is online now   Reply With Quote
Old 11-19-2018, 06:30 PM   #3
ZenzenRacing
Liked 53 Times in 17 Posts
PM sent
ZenzenRacing is offline   Reply With Quote
Old 11-20-2018, 09:29 PM   #4
Ed McLawhorn Jr.
Liked 19 Times in 17 Posts
PM sent.
Ed McLawhorn Jr. is offline   Reply With Quote
Old 11-26-2018, 06:36 PM   #5
Robert Simpson
Liked 20 Times in 12 Posts
PM Sent
Robert Simpson is offline   Reply With Quote
