Old 10-15-2018, 07:53 PM   #1
devo340
devo340's Avatar
Liked 168 Times in 30 Posts
Default 360 mopar oiling
Whats the trick to keep #6 rod bearing from spinning in my stocker?
Have lost it on the first engine, stock block & crank.
Just lost it in a Race block & different crank.
Have built several Small block MoPars for bracket racing, no bearing issues.
Tell me what I'm doing wrong.
devo340 is offline   Reply With Quote
Old 10-15-2018, 10:07 PM   #2
CMcAllister
Liked 920 Times in 259 Posts
Default Re: 360 mopar oiling
RPM? Any oil system mods, yet?
Old 10-16-2018, 06:19 AM   #3
devo340
devo340's Avatar
Std pressure pump.
Feed to the rocker shafts restricted.
Maintains 65PSI @ idle, 70PSI @ 7100RPM
Old 10-16-2018, 04:06 PM   #4
Coleydog
Liked 53 Times in 38 Posts
Since you have to use a stock pan, my guess, running out of oil in the sump. Are you using the center sump pan? If so use the Magnum rear sump pan, it will fit the 360 engine. Run more oil, keep it from foaming, air compresses, oil doesn't. Run thin oil, to heavy an oil can't get back to the pan quick enough. Just my opinions...
Mike
Old 10-16-2018, 05:47 PM   #5
jmcarter
jmcarter's Avatar
Liked 3,199 Times in 977 Posts
Had a Dakota pan on my Volare 360 and had no issues so agree that if using the center sump pan you’re probably running it out of oil, especially if you’re taking out oil for ET...probably turning it higher than bracket motors, what is it turning in the traps?
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 10-16-2018, 05:58 PM   #6
Ed Wright
Ed Wright's Avatar
Originally Posted by devo340 View Post
Std pressure pump.
How much clearance? What's the crank journal diameter?
Ed Wright 4156 SS/JA
Old 10-16-2018, 07:35 PM   #7
65signet
Liked 49 Times in 22 Posts
Had that happen to me, on a bracket engine,we did some mods to oil passages, and cut the oil off to the lifters.
Steven Barnes
Stock 704 N/SA
65signet is online now   Reply With Quote
Old 10-16-2018, 07:55 PM   #8
devo340
devo340's Avatar
Mike
Using a Dakota rear sump pan.
5 quarts of oil with big oil filter.
Old 10-16-2018, 08:06 PM   #9
devo340
devo340's Avatar
2.5-3 clearance
rod journal 2.125
main - 2.80
Old 10-16-2018, 08:12 PM   #10
nolongerracing
Liked 72 Times in 27 Posts
If you are using the newer R block that has the lifter valley closed off, you need to provide more drain back to the pan. Also check the oil filter mounting boss. That area is different than the stock blocks and you will need to add an extra cork gasket between the plate or adapter and the block. If you are running the filter plate, make sure it has 6 or 8 holes and not 4 as some plates do.
nolongerracing is offline   Reply With Quote
