#21 | |
Liked 251 Times in 125 Posts
I'm sure the bottom line is a matter of following the money trail. My 87 Mustang street car needs a roll bar if the air is good. (11.40's) I don't want the seat belt hassle, so no roll bar, and I only go when the air is bad. I have no problem with a roll bar and race belts, but just let me use them (race belts) for more than 2 years! I hardly ever run it. But, I digress. I can't help myself when I see these roll bar threads. |
#22 | |
Banned
Liked 235 Times in 110 Posts
#23 |
Banned
Liked 179 Times in 89 Posts
Why won't the NHRA rewrite the rule so they're not legally responsible for the seat belt like NASCAR?
#24 |
Exactly! What I do with my street/strip car is disconnect the back carb barrels. slows it about 1/2 sec. or i carry weight, and can also adjust timing, easy peasy! Some use one of the mechanical stops. whatever gets the job done. like many, I just don't want to put a roll bar in a pristine 67 dodge coronet that is still occasionally driven on the street
#25 |
Liked 54 Times in 33 Posts
NHRA: "We REALLY don't mind if you get injured." ...............or worse.
#26 | |
I have a few more things I'd like to do to the car. It's a toy, and I like getting what I can out of it. It'll probably go low 11's with what I want to do. I've always understood that there has to be a line (et) somewhere where a roll bar is required, and I'll eventually do the roll bar. But now, because a car is quick from the factory, it's safer than mine? |
#27 | |
Banned
#29 |
Liked 372 Times in 130 Posts
Yep.
When I ran 11.80's in N/SA 4 years ago a helmet was all that I needed and my 28 year old seat belts
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#30 |
Liked 53 Times in 38 Posts
A roll "bar" is nothing more than a suppliant to the car, whitch the car is considered a cage of sorts. If being highly safe, a funny car roll cage is your only option, the rest is a money grab, pure and simple.
Fighter jets go longer than two years on belts, mostly after 6-10 gs I think. The dumbest, blow shield re-inspection, 1/4 inch steel goes bad I guess. |
