#1 | |
Liked 189 Times in 48 Posts
Since you mentioned alcohol I'll share an experience I've run into a few times in the last several seasons. A few seasons ago I picked up a dragster to bracket race with. It was a typical BBC run on methanol when I got it, and I raced it exactly the way it was, never changed a thing. I had no prior experience with running alcohol. I had good luck with it right off the bat. Anyway after a while it developed a miss. It wasn't terrible, I was still able to race with it. But after checking all the expected things (crank trigger, rotor, wires, wiring, coil, ignition box etc) with no success another experienced alcohol racer asked me if I had changed the plugs. I had changed the plugs recently but it was a short time before the miss developed so I really didn't think the plugs could have anything to do with it. A few mins later he showed up at my trailer with a few boxes of new spark plugs and insisted I change them. He ended up being right... the miss was gone. Since then, it has happened again and a spark plug change was the fix. What he told me was that with alcohol plugs don't seem to last as long as when running gas. Give that a shot. Good luck.
Angelo DiTocco '98 Firebird SS/HA '98 Firebird B/SA |
Liked 799 Times in 236 Posts
Don't overlook the coil wire. -Al
"That'll never work....." |
