Liked 196 Times in 29 Posts
If anyone is interested in seeing these parts, please contact me and I will bring them to Maple Grove for the Dutch Classic next weekend or the Indy Fall Classic in a couple weeks.
HURST Pistol Grip Shifter with Large Plastic Black Cover - Shifts From Front to Rear "P-R-N-1-2-3" Reverse Valve Body, Fits GM Transmissions. Wired for Park-Neutral Safety Switch and has Top "RED" Button on shifter for however you want to use it. $350.00 Plus Shipping STAHL (Ceramic Coated) Big Block Chevy Headers for Gen 2 Camaro - 2" Primary (30" Long), 3-1/4" Collector (15" Long), 8 EGT Fittings Installed, along with 8 O2 Bungs installed in each tube. $525.00 Plus Shipping M200 Gearset from Leo - First is "2.57"- Second is "1.54" $500.00 MAXPWR from Tech West. MAXPWR solves the problem all racers run into when running without an alternator or during competition loosing the charging system. The battery voltage will drop and drift around while the race engine is running. MAXPWR eliminates this issue. $325.00 I can be contacted via the message system on this forum or call at 33zero-two19-four738, please leave a message on my voice mail if I do not answer and I will return your call. Thanks Class Racer... Gary Merrick 3522 Stock |
Liked 974 Times in 310 Posts
Pm sent
