Liked 95 Times in 12 Posts
I'am turning my 63 Plymouth max wedge bracket car into a class car. I was wondering if TTI 1/78inch mild steel headers would be adequate or do I need to switch to a larger diameter stainless steel header from one of the current header builders. Thanks for the responses in advance.
Liked 132 Times in 27 Posts
Call Performance Welding Headers 530-367-4124 Best header guy in the business, the Indy qualifying sheet doesn't lie.
#3 | |
Liked 358 Times in 83 Posts
Try this explanation instead: "I'm turning myself, currently a sane, solvent individual who has a great deal of fun bracket racing, into an insane, insolvent maniac, who will pour seemingly endless amounts of money into a car that will never be quite fast enough for me, and which I will only on very few occasions, actually enjoy". Now we can all relate to what you're asking, because you've identified yourself as one of us. ![]() |
Liked 3,211 Times in 980 Posts
xxx double posted
Jim Carter 2340 Super Stock 2340 SST/2340 Stock Set another place at the table Last edited by jmcarter; 09-19-2018 at 07:57 AM. |
X2. Mark Lelchook is a absolute master craftsman. Based on his experience he can tell you power curve on different styles and diameters. Guarantee his stuff will fit too.
Liked 20 Times in 12 Posts
Give Robbie McDonald a call @ outlaw headers 704-230-6429 located in Mooresville ,NC Does only stainless makes everything in house flanges,tube bending and the best collector out there.
#7 | |
Liked 129 Times in 53 Posts
For what you are trying to do it's probably a good way to start with TTI or similar priced Headers and spend the $2500 that you save on other things to make the Car faster and better,..that said....I already have 2 sets from Mark and may buy another set in the future, because I REALLY LIKE this type of ART!!! ![]() |
Liked 29 Times in 14 Posts
I would try KromerKaft in Youngstown, OH (330-539-5053). Engine size and expected peak HP rpm are required to determine tube size and length. When it comes to Stock/Super Stock/Comp, the header needs tailored to the specific engine. I used to do most all the computer simulation for Kromer to determine header sizing back in the late 1990's & early 2000's . Mild steel + GOOD ceramic coating (inside & outside) will save you money over stainless.
Thanks, Ron Last edited by RonP; 09-21-2018 at 08:38 AM. |
Liked 7 Times in 5 Posts
i've heard several people have had good results with REF unlimited in arizona. if you buy a shelf header you might look into a program like pipemax to help determine primary size.
I have raced a bunch of these cars.
At least 2 inch tubes = Hooker has made Thousands and they are cheap used. Even their 2 x 32 street header is fine. 2 1/8 inch are marginally faster on a quicker car. Steps/Merged are certainly a bit better = Cost is three Thousand VS three or four Hundred bucks I have several sets of Hookers laying around the shop (Clarification: The Headers NOT the girls).
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 09-22-2018 at 01:16 PM. |
