Liked 32 Times in 13 Posts
Need advice for a reputable diesel repair service in Indianapolis that will work on 02 Dodge 2500 diesel. Truck just stopped running. Has p pcu and p ECU codes, no numbers after. Thanks for any responses.Dealer says it will be two weeks before they can look at it!
Call Fleece Performance Diesel- Brownsburg - they might help
..317-286-3573
Chuck Westcott- S/C -S/G 225 |
Liked 539 Times in 112 Posts
Fleece is awesome. They fixed a friend's Dodge diesel 1-ton at IRP just a couple of years ago.
Jim Kaekel 3836 STK |
Called Fleece and sounds reasonable but if not easy fix could be 3 weeks
Liked 314 Times in 177 Posts
Liked 145 Times in 32 Posts
Give us a call, we will help any way we can.
The Loge’s 925-584-8402 |
It's usually the injection pump on those trucks. Couple thousand dollars will fix it right up.
2009 V/SA Record Holder |
I want to thank all the people that helped or offered help the Irvings, Mike Loge, Biil Bagley, Bruce Gibson and others. It came down to bad gas and thanks to Mark at Diesel and Turbo in Indianapolis for getting it in and out and on the road again. Now to concentrate on racing. I made the field!!
Liked 31 Times in 10 Posts
That's great news Buddy! We know you meant 'bad fuel', and that's ok. You're a gasoline guy - Right? Holler if you need help shuffling vehicles to get things back in order.
Bill Bagley 4561 STK Endeavor to Persevere! |
