Old 08-23-2018, 08:51 PM   #5
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: quadrajet 455ho
There is a special system that the 1971 455 HO carb has , its called the POE system . Its purpose is to add extra fuel at WOT . You may want to get the Quadra Jet book by Cliff Ruggles , he has a section on that system . Most Q-Jets do not have that system , it doesn't meter fuel as well as having fuel go through the venturies . You say your engine only runs rich in 1st gear , are you running a Ram Air hood and air cleaner ? Which body style , GTO , Formula , or Trans Am ? Each has a different system .
Check Fig 11 https://www.gmcmi.com/wp-content/upl...ice-Manual.pdf
