Old 08-20-2018, 09:24 PM   #581
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: H-I-J '76 Nova re-fit.
Originally Posted by Painter View Post
General regulations require it be welded. Whoever replied to your email must have only looked in the "Stock" section of the rule. I got caught on it is how I know. I got mine from Summit and don't think it moved the wheel at all.
If that is the actual case and was called on it I would just go with the swing-out bar myself...makes all the difference in the world getting in and out of many of these cars. Those high side bolsters on the aluminum seats compound the problem.
Rich Taylor
I/SA - 321
Old 08-20-2018, 09:25 PM   #582
Nmbr1GMfan
Thank you. And which one did you use?
Todd Greene
Old 08-20-2018, 09:28 PM   #583
Painter
Liked 162 Times in 45 Posts
I am a long way from the car, but knowing me it was the cheapest!
Painter is offline   Reply With Quote
Old 08-20-2018, 09:54 PM   #584
Nmbr1GMfan
Haha gotcha thanks.
Todd Greene
Old 08-21-2018, 01:59 PM   #585
nickh
nickh's Avatar
Liked 650 Times in 194 Posts
Todd the car is a piece of art. Attention to detail is breath taking.
Old 08-21-2018, 04:26 PM   #586
Nmbr1GMfan
Thanks Nick, Much appreciated. It's been a great ride so far. The real fun will be next year when we see how good we are at making this thing haul *****!
Todd Greene
Old 08-22-2018, 06:05 PM   #587
Nmbr1GMfan
Been a rough week at work so far and I haven't gotten anything done. Autumn has been running parts around after school and I finally got in the shop for a couple hours today. Made the last ground strap, the starter cable, and it actually turned over for a second so that works. Started working on the brake pressure gauge so I can get the last flex hose made this week to button up the brake system.
Todd Greene
Old 08-25-2018, 10:13 PM   #588
Nmbr1GMfan
How does a 20 minute job take 3 hours! My wife simply calls it... car time.
Made a thread chase to work on the wheel stud threads, got them all straightened out. Put a new set of studs in and finally got the rear back together. Brakes are on, brake lines are on, pressure gauge is mounted and plumbed too. We started to run the fuel lines for the final time too. Autumn worked on the tank brackets and of coarse drilling and tapping the radiator for no other reason than why not change EVERYTHING since that is our current theme. Back at it tomorrow!
Todd Greene
Old 08-26-2018, 09:33 AM   #589
Gary Merrick
Gary Merrick's Avatar
Liked 196 Times in 29 Posts
Hey Todd,
When you do it RIGHT the first time, you will never have to touch it again, no matter what the project is. Obviously, you and your daughter are doing it RIGHT.....
Congrats on the build, it is Very Special!!!!
Gary Merrick
3522 Stock
Gary Merrick is online now   Reply With Quote
Old 08-26-2018, 04:48 PM   #590
Nmbr1GMfan
Originally Posted by Gary Merrick View Post
Hey Todd,
Gary Merrick
3522 Stock
Thank you Gary.
Todd Greene
