Old 08-14-2018, 03:04 PM   #2
FED 387
Liked 336 Times in 183 Posts
Default Re: MSD ignition coil ground wire
Larry. It's an insurance wire to make sure you have the coil properly grounded thru the isolation mounts also helps eliminate tach signal issues--- Dick
