Old 07-25-2018, 09:32 PM   #1
SSGN
SSGN's Avatar
Liked 203 Times in 52 Posts
Thumbs up Super Stock 454
Super Stock 454 Engine
- 454 +.060 over 8.5 Compression
- NHRA rated at 341 HP
- Studded 2 bolt block that is partially filled.
- Bushed lifter Bores
- Calico coated bearings
- Custom Comp Cams Roller
- Crower Lifters
- GM Steal crank
- Eagle steal rods
- C/P 3 ring pistons and pins
- ATI Dampener
- Custom Steal Oil pan
- Cylinder heads are 236 casting with welded D port exhaust
- Ferrea Valves and Manley springs
- T/D 1.7 rocker assembly
- Composite valve covers
- Matching ported intake
- Q-Jet carb
- Wilson Spacer
- MSD Billet distributor.
This engine is fresh and ready to go. Complete carb to pan , flex plate to dampener. In this configuration it made 700 HP and 600 FT/LB Torque. I have dyno sheets and flow numbers for the buyer and any spare engine related parts ie bearings etc can be negotiated. This engine will go 1 second under and is a proven combination.
$ 12,900 US
The more people I meet the more I like my dog
Kevin
