Liked 1,104 Times in 302 Posts
I am looking for a good mainshaft for a wide gear Jerico DR4 4 speed transmission. Also looking for a Ford T5 depth DR 4 input shaft with 1 3/16x18 spline .
Liked 520 Times in 132 Posts
Measure your input shaft. I might have one.
Liked 45 Times in 20 Posts
Give me a call 605-279-2827
Ed, my input measures 7" from the pilot tip (Ford diameter tip) to the snap ring groove for the front bearing.
Rory, did you use gum to measure that input? Or, some other less accurate means than the 'soccer Mom' method?
Good luck with your search. |
Ok I’ll check
THanks Ed, let me know. I guess you don`t have a mainshaft, do you?
Liked 172 Times in 46 Posts
Rory did you find an input? I just converted a ford wide gear to a chevy. Ford nose 18 spline.
Dirk
Dirk Olson 5036 STK |
Dirk, sent you a PM.
Liked 6 Times in 6 Posts
Rory - Contact Jerry P at 509-910-9419 --he has a completely reconditioned Jerico w. Ford input and brand new Long shifter for $2200.
