Liked 3 Times in 1 Post
Hello, I am a bracket racer but have learned a lot from this forum. I bracket race a 65 Comet with a 351C, Jerico with 3.08 first and a 4.86 gear. Leaf spring/ladder bar car. Currently runs 10.50's at 127 mph. My rear tires are probably 12 years old and pretty much done. I do not race a lot. I can only fit a 9" tire and have been using the regular 3054. I see they have a 3054 ST which is a harder compound tire.
I am trying to determine if ST tire would be better? I am also wondering why a harder compound would be more stick friendly? My local track starting line is not that great. Any advice appreciated. Not opposed to Hoosier or Goodyear. |
Liked 22 Times in 16 Posts
The ST is for a stick car
Liked 20 Times in 15 Posts
You want the ST's as mentioned D07 compound. I have had both M/T's and Hoosier's. Hoosiers don't leak at all. Mickey's sure do.
QUOTE=b.guggenmos;568280]Hello, I am a bracket racer but have learned a lot from this forum. I bracket race a 65 Comet with a 351C, Jerico with 3.08 first and a 4.86 gear. Leaf spring/ladder bar car. Currently runs 10.50's at 127 mph. My rear tires are probably 12 years old and pretty much done. I do not race a lot. I can only fit a 9" tire and have been using the regular 3054. I see they have a 3054 ST which is a harder compound tire. I am trying to determine if ST tire would be better? I am also wondering why a harder compound would be more stick friendly? My local track starting line is not that great. Any advice appreciated. Not opposed to Hoosier or Goodyear.[/QUOTE] |
Liked 24 Times in 8 Posts
Liked 6 Times in 2 Posts
As mentioned, the ST is the tire you want and don't worry about running tubes. Also keep in mind that different brands have more or less section width with Goodyears seeming to be the narrowest for any given size. If you have a tight fit now this may make up your mind on brand.
Dale Posnick |
Liked 10,789 Times in 2,242 Posts
The Goodyear 1909 is a big tire compared to the rest of the 9'' tires.
Liked 99 Times in 60 Posts
just food for thought, take a look at the Phoenix tires. They are gaining in popularity and one of the advantages, they generally have the most narrow section width of all choices.
Larry Woodfin 471W |
Liked 77 Times in 15 Posts
You want the Hoosier stick tire that we run on stockers. It will work great on marginal tracks.
#9 | |
Running radials, tubeless? Every Hoosier I've had leaked right through the sidewalls. The MTs I ran last year (I just walked out there to make sure) still have over 10 psi. I run them at 13. I have not use a Hoosier in two years, maybe that got better.
Ed Wright 4156 SS/JA |
Liked 312 Times in 175 Posts
Ed: I have been running Hoosier radials for at least the last 10 years, and no problem with sidewall leaks
