Old 06-29-2018, 11:27 AM   #7
dwydendorf
dwydendorf's Avatar
Liked 19 Times in 7 Posts
Default Re: 8.5 S Spring Posi
The original posi units were made by Eaton. I think you can still get the original type clutches through a dealer that handles the Eaton parts.
The factory clutches were broken in on a break in machine after being soaked in a pan of gear lube. You could do something similar by assembling the differential with preload plates and springs and turning the axle a half dozen times in each direction. It won't apply as much pressure to the clutches as the breakin machine did but it would be better than what you have now.
ss/gt 93 t-bird
dwydendorf is offline   Reply With Quote
