Liked 53 Times in 38 Posts
Has anyone welded up the seams on the k-frame ( just spot welds now)? Do you think it's necessary?
Mike |
Liked 62 Times in 17 Posts
Weld reinforcement around the LCA shaft boss for sure. Steering box mount needs some help too.
See www.firmfeel.com
Never had a problem with a stock one EXCEPT in early 70's when I acid dipped them (Bad Idea)
Liked 21 Times in 13 Posts
Mike, if you put a notch in it for oil pan removal, as per rule book, make sure to off-set it 2" to the right.
Brian Carpenter Stock 1358 |
Liked 138 Times in 51 Posts
It certainly can't hurt. In addition to frame connectors and roll bars/cages, I've heard of cases where people have also welded the body & frame seams on Mopars, all in an effort to minimize any bit of potential flex in the uni-body chassis.
LOCOMOTION Racing |
Liked 10,769 Times in 2,238 Posts
With all the welding that is needed, it would be necessary to tie the "K" member down to steel plate to keep it from looking like a corn chip after welding. To reduce some stress from welding, peen it with a numatic chipping hammer. Let it cool before removing.
Thanks for all the answers, now I have to take the fresh paint off. Wish I'd thought of this before. LOL
Liked 239 Times in 114 Posts
While you are at it , weld on some tie down loops .
Liked 88 Times in 43 Posts
AND While you're at it. When you brace that steering box mount.....don't you DARE cut it off and move it over for more header clearance.
