Going to try some S/ST racing...Have a '68 Nova that weighs 3290, Powerglide, 4.10 gears, 9 inch slicks, 454, has been 10.06 at 135.60, usually 10.15-10.25. Going to be running a plate stop, thinking that will put it at around 10.25-10.35. For first time out: .3, cruise at 4600, 1.8, and shift at 6600 after coming off the stop. Looking for feedback, or suggestions if you see any.
Liked 274 Times in 143 Posts
How tall is your tire?
Liked 431 Times in 224 Posts
Your Nova is fairly similar to mine. Mine is 300# heavier and has a 4.30 gear, and you are probably a tenth quicker.
I go on the stop at 0.500, "cruise" at 4200 although it isn't really on the stop long enough to sit there, and I'm off the stop between 1.2 and 1.8 depending on weather and track. In the summer at midwestern 1000' elevation, it is usually 1.35 to 1.6. I think your suggested numbers will put you a little bit slow, but fairly close. Your ratio should be very close to 3:1 at that RPM.
S/ST 51 S/C 53 |
#5 | |
Awesome, thanks for the reply, looks like I'll be close then..was thinking 3:1 to keep some numbers to play with, 2:1 may be under 1 second in bad weather. Do you have it at .500 to get your car out of the beams and cut a light, or to help get some momentum and keep some numbers on the stop? |
#6 | |
The least amount of stop time I've ever used is 1.19, into a headwind at Topeka in 3500 foot air. I should probably be using a higher stop RPM, but I have a setup that works so I'm hesitant to change it.
S/ST 51 S/C 53 |
I think the car will be slow as well at first. Definitely not going to have much of a top end charge with the 4.10's.
Have you considered not using the stop, and dropping your shift point to slow the car down? |
#8 | |
Learn to make the lack of top-end charge an advantage! You control the race from out front.
S/ST 51 S/C 53 |
It's a designed footbrake car with a loose converter, so it flashes to 5800, I shift at 6500 and go through the stripe at 7000/7100 at 132-135 throughout the year. It had 4.30's but was going through at 7400 on the chip. So a lowered shift point will not change it enough, and I don't really want to add weight because as it is I am a little worried about the .470 tree.
#10 | |
