Liked 544 Times in 213 Posts
I ran my LT-1 stocker with 50lbs of fuel pressure and at that time ran 24lb Accel injectors. It went 10.50's in real good air at 125 in the then separate A/FIA class.....Car was about 200 lbs over the weight minimum for the class....
After selling the car I was given the opportunity to drive it again for 2 weekends. It still was run with around 50lbs of fuel pressure and had bigger injectors. It was a little heavier than when I ran it and ran 10.50's in real good air.....running B/SA.....It had a better engine and much better fuel map tune up. The car ran some 10.20's at Atco before the HP was hit a while later.
Rich Biebel S/C 1479 Stock 147R Last edited by Rich Biebel; 06-09-2018 at 04:02 PM. |
Dan, your factory injectors were 24lbs. '97 &'98 LS1 injectors are rated at 28 lbs. '99 & later are 26lbs. Stock LT1 cars are all too rich @ WOT from the factory. More injector won't gain you a thing. If not tuned for them, they will slow you down, unless there were issues with your factory injectors.
The LS1 uses 58 to 60 psi, which of course makes them flow more in use. Not likely the IHRA Tech guys would think about checking the numbers on your injectors, nor have the numbers on file, or may not even care. There is no power there, running LS1 injectors at the fuel pressure you are using. If the IHRA rule book does not state that you can use different injectors in Pure Stock, even if the tech guys don't notice, and you are using them, you are simply illegal. Sneaking something past Tech simply does not make it legal. If the tech guys knew enough about it, and cared, the LS1 injectors do look different. I would know if I saw it. No power there, just illegal.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 06-09-2018 at 07:50 PM. |
Rich, higher fuel pressure atomizes fuel better. Better odds of every cylinder firing every time. In the real world they seldom do. My GM Calibration Engineer friend was telling me the power & emissions improvements they saw when developing the LS1 engines when going from the ~ 36/46 psi fuel pressure used with the LT1, to the ~60 psi for the LS1.
I had to go to 42 lb injectors for my LT1 Super Stock engine, to get the injector duty cycles comfortable @ 45 psi. I started thinking about that. I went to 36 lb FAST injectors @ 60 psi. They tested the same there as the 42s @ 45 psi. On my old Dynojet chassis dyno, A-B-A testing, dialed the air/fuel ratio to the same 12.8-1 it likes on C11, picked up 9 hp at the tires. Obviously some misfires going on we could not here. My GM guy predicted "8 or 10", saying "They all miss some, all the time. Has to be bad to hear it." I thought the gains had to be a fluke when I changed them. Changed them back (as in A-B-A testing) and it dropped back off. Changed injectors, tune & fuel pressure again, picked it right back up. Had to call him to thank him. LOL
Ed Wright 4156 SS/JA |
Liked 239 Times in 114 Posts
The formula for determining a different injector flow rate by changing the fuel pressure is :
(Square root (New Pressure/Old Pressure)) x Old Flow Rate = New Flow Rate So if you go by Dans' combo where he stuck in LS1 injectors (24lbs@58psi) and he lowered the pressure to 43psi . The rating would now be (21lbs@43psi) . Basically a wash compared to a stock LT1 injector which is (22@43psi) . Its important to know what pressure is used when comparing injectors |
The LT1 & LS1 injector flow rate data is certainly different that I was given. Guess maybe all GM engineers don't all have the same data. Do agree that Dan made a useless change to his now illegal car. LOL
#6 | |
Liked 184 Times in 113 Posts
They said ok!...they work fine. Bought them because could not find LT1’s. LS1’s were available and popped right in. |
Liked 2 Times in 2 Posts
I am new to F.I. How do I determine which ones I have? How do I know when/if they need to be replaced?
#8 | |
They very seldom need replaced.
My Rochester injectors had part numbers on them . The Ford Motorsport injectors are color coded . You could also remove them and send them to get them flowed . Also make sure you know what pressure your injectors are running at in your car .
