Liked 83 Times in 20 Posts
I tested my new 8 “Advanced Aluminum Billet clutch today. In 120 degree track temperatures I went 1.442 60 ft times. Made three runs and all three had 60’ times of 1.441 to 1.443. The track temperature on the last run was 135 degrees. Even with the air temperature at 95 degrees, I ran within 3 hundreds from the best run to the worst run. The adjusted altitude was 3700 feet and rising. The heat was brutal at No Problem.
John Duzac D/S 4448 STK |
Liked 91 Times in 29 Posts
Totally impressive. Just noticed it advertised yesterday on their website. Love to have it, but probably way over budget.
Bruce Cameron 68 Nova 396 E/S 68 Camaro SS/? ex Checkmate Modified |
Liked 2 Times in 1 Post
Sounds like a keeper to me. Some good 60’s for a hot track.
Derek Hake 4459 H/SA 69' Roadrunner |
Liked 684 Times in 289 Posts
Just call Rob Youngblood he will fill you in. This new clutch will can be adjusted to slip in first gear. Plenty adjustment room. This is a nice piece.
Bruce, that clutch is cheaper than you think. The way I did it was to put so much down and send a check or two. Before long it was paid for. It’s the way to go.
Mike, I fpund it when I googled Advanced Clutches and clicked on Index
Thanks Bruce
I clicked on home button on their website:http://www.advancedclutches.com/index.htm Thank you |
