Liked 90 Times in 52 Posts
what manufacturer offers a replacement 2 piece neoprene rear main seal to replace oem Rope for 1972 Buick 350 ?
Liked 993 Times in 199 Posts
TA Buick performance in AZ. has the 4 rear neoprene seals for a Buick 350 in their catalog for $16.95. I have a 72 350 4bl intake manifold if you are looking for one.
Liked 974 Times in 310 Posts
Use a ford 460rear main seal.
Thanks Glen .. to think that a Ford main cap has same dimensions as the Buick in seal area
Liked 89 Times in 19 Posts
That's priceless!! An old-time rebuilder advised me that a rear main seal for a 312 Ford would work in an Oldsmobile 307 and that the rope seal could be avoided altogether. Didn't believe him until I tried it.
c
Chuck Norton |
Liked 88 Times in 43 Posts
I thought the 460 Ford worked in 455s, and the 350 took the same seal as the V6. Long ago I worked at Jim Ruggles' when we switched from rope to rubber. I thought the seal we used was from an AMC, but it's been a while.
I see that FelPro sells a neoprene seal for the V6s BS40613. Either way, make sure to polish the knurls down or it can chew the edge off of the neoprene seal (that much I do remember). |
#7 | |
They did have a pressed in rubber seal in the front timing cover however.
#8 | |
