Liked 24 Times in 13 Posts
Is there a right and/or wrong place to install a fire exting. per NHRA rules.
I believe I have a good extinguisher on order and the proper bracket. Terry K |
Liked 800 Times in 237 Posts
Terry, I mounted mine on the bar that runs alongside the passenger seat.
"That'll never work....." |
That sounds like a good idea Alan.
Problem is that I still use my stock seats('78 Camaro) and the side bar is so close that I have no room. Are you allowed to put the "thing" on the cross bar between the two seats? I have lots of room there. Terry K |
Liked 33 Times in 16 Posts
Carried one in the Camaro when it was in Stocker trim.
Rich Taylor I/SA - 321 |
Thanks for the picture Rich.
Had you ever considered placing it between the seats on the cross bar? I like the orientation of the "thing" on your passenger side bar though. Terry K |
I actually put it there so someone else could grab it quickly from outside...you could easily see it thru the window with the door closed.
