#1 | |
Liked 184 Times in 113 Posts
Right now I am working a lot of hours. Plus train daily to Ref Soccer games. Next two weekends Reffing Elite Soccer Tournaments. In the mean time collecting parts for Stock. Before adding power better to build safety and reliability. First a Roll Bar then a Beefed 8.5 rear with Ford Ends. Those are my next two investments. As for hands on...when I got time and can borrow a garage I do the work. Otherwise have a couple close mechanic friends do the work. I do appreciate your advise. Will ping you off line. D |
Liked 239 Times in 114 Posts
The bummer with having a converter built for a 4L60e is it will only fit a 4L60e . So you will own it forever . There is a lot of support for a 200 , and the transmission is dramatically lighter . Even though you have a heavy car , there is some value in being able to place the weight where you want it .
That 4L60E belongs in a daily driver, not a race car. Listen to Mark.
Ed Wright 4156 SS/JA |
Liked 358 Times in 83 Posts
Liked 16 Times in 11 Posts
I side with Mark, make the switch and you will save $$$ Mark has built some odd combos with much success and knows what works and what dose not. Ed is like me, (old) but very smart, listen to them.
Bob Pagano A/SA |
#6 | |
Nice to hear from you.. Always loved that picture ! Mark et ALL! Which 200 Trans are you all talking about? There is a 3sp and OD model. Other posters recommended a Lightened 2.75 1st gear Turbo350 Never got more than 200 runs out of a Turbo 350 in my 69 Impala. Had 1978 Oldsmobile and 1980 Pontiac Wagon with a Th200 trans. Which got rebuilt every 20,000 miles like clockwork. Few questions? Will the car need a new X Member, Drive Shaft, if so what length? My 4L60E has been a very robust unit and ATI has a converter for it. Know Corbitt Marshburn used one on his Car. Have well over 500 runs and a lot of street miles. Prefer reliability over a tenth. D Last edited by Dan Fahey; 05-16-2018 at 12:36 PM. |
Use a 200-C
Current crossmember will work with minimal modifications Driveshaft will be longer , but you should convert to 1350 u-joints , which will need a new companion flange and front yoke . Output spline is the same on a 200-C as a 4L60e , but you will save yourself some headaches making the switch to a 1350 u-joint . |
