Old 05-08-2018, 02:48 PM   #16
brian schuetta
Liked 28 Times in 15 Posts
Default Re: 1986 tpi 350
Got the whole thing tore down, yes it was rebuilt. Two bolt block, one - piece rear seal, .060 over hyper pistons. The 261? heads are 1.72/1.5 valved with large chambers, totally useless except for shop cores. I plan to sell the TPI setup, manifold, runners, plenum, throttle body, and fuel rails. Those parts are from an 85-87 F-body. The bottom end will be cleaned up with new bearings/rings and sold either like that or running with different heads. I'm keeping the exhaust manifolds with the air tubes and connected lines for that system.
brian schuetta is offline   Reply With Quote
