Old 05-01-2018, 08:49 PM   #11
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Default Re: Chevy engine blocks origin ?
My dad worked at the Flint plant for 18 years.
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 05-02-2018, 06:39 AM   #12
Pat6868
Liked 88 Times in 28 Posts
At the St.Catharines Ontario plant we assembled 1500 small block engines in an 8 hour shift using blocks cast on site in the foundry. This was mid to late 70''s.
Pat6868 is offline   Reply With Quote
Old 05-02-2018, 10:19 AM   #13
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
Originally Posted by FED 387 View Post
Possibly Toluca Mex foundry
The Target master I am disassembling was dated '89. The block,crank,heads and pistons all marked Mexico. It was purchased about 1989 or 1990 installed briefly and then involved in an accident (write off). I am not sure of the mileage but so far it looks really clean and decent inside. Owner was a Valvoline diehard. I did notice the crank casting looks very rough and the finish almost appears as if a coarse wire wheel was used on counterweight flash.
(4 bolt main, cast crank, cast dished pistons, 993 heads, single link timing chain...)
Old 05-02-2018, 10:25 AM   #14
FED 387
Liked 333 Times in 180 Posts
my understanding is that these engines "did not last very long" generally til a little while after the WARRANTY expired--- never had one never saw one I have no experience wit them other than GM supposedly discontinued them due to numerous complaints relating to quality and engine life---these engines were sold at a lower price than the "regular" GM replacement stuff--- I guess it all comes down to you get what you pay for!!
Old 05-02-2018, 12:06 PM   #15
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
How many people were assembling engines?
Old 05-02-2018, 06:21 PM   #16
Pat6868
Two assembly line's, can't recall total number of workers. Iirc engines came by 3 or so a minute, we had 16 guys pushing pistons. It was 40 years ago.
Old 05-02-2018, 06:24 PM   #17
FED 387
1500 per shift thats about 190 engines per hour or 3 engines per minute-- no standing around here folks--
Old 05-02-2018, 07:12 PM   #18
Tim H
Tim H's Avatar
Further to this discussion,I found this post on the NCRS site
When I was the Senior Process Engineer at the Chevrolet Pilot Line in Flint in '66-'69, a good friend was the supervisor of the Piston Department at Flint V-8 next door, and I spent time there on several occasions. They didn't stamp the rods and caps when they machined the rods and made up the piston/rod assemblies for the engine assembly lines at 2400 rod/piston/pin/ring/bearing assemblies per hour; they just placed the size-gaged cam-ground pistons in the correct position in the 8-piston conveyor trays to match the teleprocessed bore sizes for that engine from the bore air-gage station at the head of the line.
Old 05-02-2018, 08:16 PM   #19
Pat6868
At St. Catharines blocks would come down line upside down. Bore size was stamped on pan rail ( A,B,C ) etc. Workers would choose matching piston-rod assembly and install main bearings. Then place in order beside engine. Then we would pop them in and install cap and nuts.
Old 05-03-2018, 01:38 PM   #20
Bruce Fulper
Liked 54 Times in 33 Posts
Ya think all those ring end gaps were in position? :-)
Bruce Fulper is offline   Reply With Quote
