Old 04-26-2018, 02:08 PM   #1
FED 387
Liked 333 Times in 180 Posts
Default 904 tf ???
anybody use a 904 TF trans with the Chevy bolt pattern bell housing???
Old 04-26-2018, 02:16 PM   #2
SSDiv6
Liked 1,604 Times in 583 Posts
Default Re: 904 tf ???
Let's have a moment of silence...
Old 04-26-2018, 02:20 PM   #3
race watcher
Mail Truck
race watcher is offline   Reply With Quote
Old 04-26-2018, 03:20 PM   #4
GTX JOHN
Not a easy case to find!
John Irving
741 Stock
741 Super Stock
Old 04-26-2018, 03:45 PM   #5
jmantle
Liked 172 Times in 81 Posts
I've never seen one but from what I understand it is an actual 904 with the small 2nd gear servo and 3 pinion planetaries, not the V8 998 or 999 that most guys use to make race car transmissions out of.
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
Old 04-26-2018, 04:52 PM   #6
SSDiv6
The transmission was available in 1981 to 1982 Jeep Mail Trucks powered by the 151 Iron Duke engine and was also used in 1980 to 1983 in the Jeep CJ-8, CJ-7 and CJ-5 with the Iron Duke engine. The transmission is a TF-904 with a BOP bellhousing.
Old 04-26-2018, 05:05 PM   #7
Bruce Noland
Liked 444 Times in 145 Posts
I bought one years ago. It looked fragile and decided it was not worth the cash or the effort.
Bruce Noland 1788 STK
Old 04-26-2018, 07:07 PM   #8
FED 387
I 've got one any interest or just junk it???
Old 04-27-2018, 08:22 AM   #9
BillRandles
What little bit I know, which normally ain't alot. Larry Morgan tested one in his Firebird the last year he ran SS before he went to Comp. The negative of it as I remember was the flair up on the 1-2 shift due to the small servo. And Roy Johnson built one up wanting to try in the Opel C/EA he was driving but I don't think the owner had the same vision.
BillRandles is offline   Reply With Quote
Old 04-27-2018, 08:31 AM   #10
Rsmith38
Liked 28 Times in 15 Posts
That case was also in AMC cars with the GM 4 cylinder engine 81 to 84 years . I bought one for the 2.75 low gear set that they came with. Sold the case to somebody in CO on EBAY Case should take all the 904 upgrade stuff. A certain 4 cyl econo dragster was very fast back in the day with that setup!
Rsmith38 is offline   Reply With Quote
