Old 04-12-2018, 07:48 AM   #1
Alan Nyhus
Liked 799 Times in 236 Posts
Default Re: Nova stocker project.
Originally Posted by Glenn Briglio View Post
Those are all th200 ? Who makes the aftermarket case ?
Glenn, the cases are GM. The two on the left have J.W. Ultra Bells on them. -Al
"That'll never work....."
Old 04-12-2018, 08:58 AM   #2
Nmbr1GMfan
I was wondering also but I saw the bell on the floor. Wasn't sure if I've ever seen a aftermarket 200 case.
Todd Greene
Old 04-12-2018, 04:10 PM   #3
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Went to a Coan TH350 w/low gearset last year. I've not noticed a performance difference between the two, but I sure am liking the durability of the TH350 so far.
Rich Taylor
I/SA - 321
Old 11-19-2019, 11:35 AM   #4
Alan Nyhus
Probably time for an update.
Went -.89 under twice this season (Earlville, Iowa and Kearney, Ne.) and -.88 under at Rock Falls, Wi. Camshaft had some hurt lobes when it came apart so Matt Steen and Jason Verke at Victory Engines are once again rubbing on stuff. We'll go back to the dyno after the pieces get back and are reassembled.
Old 11-19-2019, 11:43 AM   #5
Glenn Hayes
Glenn Hayes's Avatar
Liked 18 Times in 12 Posts
Very well done and fast !
Let us know how your freshened engine works out.
Old 11-19-2019, 12:20 PM   #6
Liked 5,121 Times in 1,952 Posts
Good that you found those problems early.
Looking forward to those dyno sheets.
Old 11-19-2019, 07:45 PM   #7
Alan Nyhus
Yes...the lobes had begun to look herky earlier in the season but the leading/trailing edges of the nose were still okay. The lash wasn't changing but toward the end of the season it got 'flat' and unresponsive to changes so I wasn't surprised to see half a dozen like this when I took it apart.
The last pass on it was at the Div 5 Nat. Open at Kearney, Ne and it went -.88 and change under.
Stocker Life.....
