Old 04-09-2018, 06:11 PM   #5
brian schuetta
Liked 28 Times in 15 Posts
Default Re: 305 2bbl Heads
I found a set of 450s in the junkyard yesterday. The casting numbers were narrow compared to other castings and I don't know with them still on the car if they were a " clean " casting. Also found the 260 intake and carb but at $65 each from the yard I thought that was high. I had to look in the old car yard at Pick n Pull, the prices are high compared to the normal yard next door. I know but some of you might think that would be cheap but I do a lot of picking, buying, and flipping parts. Two big swap meets coming up, maybe I can get more 450 castings to compare to.
brian schuetta is offline   Reply With Quote
