Old 04-07-2018, 11:35 AM   #101
FED 387
Liked 336 Times in 183 Posts
Default Re: Aftermarket/Replacement Cylinder Head Rule Change
L-98 Corvette was an angle plug head too I believe---FED 387
Old 04-07-2018, 02:21 PM   #102
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Originally Posted by Jon Sarrett View Post
Actually, LT-1 heads are angle plug.
But the replacement heads listed are for 62-70 year models.NO angle plug heads during those years.
Old 04-07-2018, 04:50 PM   #103
Jim Hanig
Liked 99 Times in 49 Posts
Dwight there never alum heads for 428,390 Ford's either,but they Got them now. Cant see how the heads for the chevys would make much diff.
Old 04-07-2018, 06:09 PM   #104
6130
Liked 117 Times in 50 Posts
I'm still perceiving Stock Eliminator through 1980's glasses, because that's what I was most comfortable with. Headers, converter, ring & pinion, and a 9" tire...on a car with a VIN number. Not saying it's better or worse, just saying I'm somewhat stuck in that perceptual paradigm.
But whether I'm comfortable with it or not, Stock has moved on. Just like stock moved on from the '60s, to the '70s, to the '80s, all the way through today.
I still find Stock Eliminator fascinating, but it is more and more becoming a class that is difficult to explain to lay people, which I think hampers it's value as a financially viable spectator commodity.
Ultimately, I think that Stock is going to die, and when it does, I will very much miss it. It is (and was) a beautiful class.
Old 04-07-2018, 07:20 PM   #105
Dwight Southerland
Then NHRA's rules for Super Stock heads "Grinding and polishing in combustion chamber permitted. Welding and/or applying epoxy in combustion chamber prohibited. Spark-plug hole must maintain the stock location, size, and angle as machined by the OEM; spark-plug adapters prohibited." can just be ignored. Have you seen the combustion chambers on the Jones heads or the Edelbrock heads? I guess everybody is satisfied to be a frog in a pot with the fire on high.
Old 04-08-2018, 03:07 AM   #106
Rory McNeil
Here we go again!
This is where I will miss the IHRA Pure Stock.
Basically the Old Stock Eliminator Rules.
Crate Motors were always a natural fit.
Replacement engines were always common.
Did not morphed the Stock Eliminator concept.
"Key word is WERE! IHRA decided to drop the Stock classes. Maybe if IHRA HAD morphed into NHRA Stock classes and rules,perhaps there would have been enough contestents that IHRA would have considered Stock to be viable still."
Current rules restrict inviting the new generation of Racer to play in our sand box.
"How exactly does expecting "the new generation of racers" to follow the same rules and procedures as all the other Stock class racers have to, restrict these new generation racers from playing in NHRAs sandbox?"
You do not do not see many 20 - 30 year olds.
Do see 50’s, 60’s, 70’s and 80’s and passing away.
"From what I have seen, the vast majority of 20-30 year olds simply do not care about cars, or racing at all. When I was 15, I was counting down the days until I could turn 16 and get my learners permit, and hopefully, my own car. This just does not seem to be the case anymore, at least in more populated areas. cars are simply not a high priority for many younger people, modifying and racing even less so. I don`t think that radically changing the status quo, for the thousands of faithful racers that have participated in Stock or S/S for many years is the answer."
IHRA had the right idea with their Class Eliminator set up.
Had NHRA adopted the IHRA structure.
There would have been shift from traditional Stock.
"Had NHRA followed IHRAs "right idea" structure, maybe there would no longer be Stock classes in NHRA either. From the number of NHRA racers on this site, looking to hopefully find a spot in a National Event with a full quota, and the 1000`s of Stock Class racers that attend NHRA Nat`l & divisional races, the NHRA Stock & S/S classes still seem to be pretty viable."
D
NHRA 6390 STK
M/S 85 Mustang
Old 04-11-2018, 10:11 AM   #107
ppmracing
Liked 2 Times in 2 Posts
Originally Posted by Todd Hoven View Post
One of the candidates for a replacement head for Pontiac round port was a head made by Kaufman Racing. Everything was a go but Bruce rejected it because of angled spark plugs. Guess that is not a problem anymore as long as you race a Chevrolet.
When we tryed to get the aftermarket heads leagal for the Mopar BB , we first got the Mopar performance 452-A heads leagal for SS onley. At that time their was no way that the Edlebrock could be legal for Stock/ SS, because off onley one thing, their was angel spark plugs. Bruce told us now way ! Then after a year or so Edelbrock came with a straight plug style, and it was ok.
But that was a Mopar, not a Chevy !.
ppmracing is online now   Reply With Quote
Old 04-11-2018, 11:28 PM   #108
Liked 5,153 Times in 1,967 Posts
How much are angle plugs worth on a SBC SS'er ? Not looking for conjecture.
Real world only, please.
Old 04-12-2018, 06:44 AM   #109
Dwight Southerland
Bill Jenkins always said 10-12 HP. Chevrolet engineers said it helps more with higher compression ratio and dome in the combustion chamber, but that it was about 10 hp on flat top pistons (350 cu in, 10.5 compression). I have only seen an un-scientific test once on a 377 dirt track engine when a pair of ported 461 heads were replaced with unported 292 heads and the difference was 22 hp.
If high compression benefits more, then consider that all blueprinted 62-70 327 and 350 flattop pistons engines run between 11.5 to 12.0 compression.
Old 04-12-2018, 08:42 AM   #110
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Unhappy Re: Aftermarket/Replacement Cylinder Head Rule Change
Stock Elim. DIED in 1985 !
