Liked 117 Times in 50 Posts
Billy? Mark?
The 2003 car is an 11.46 pound car, and the 2004 car is a 10.59 pound car. The 2003 car will run AA/FS at 2656 pounds, and the 2004 car will run AA/FS at 2865 pounds. 13.50 index. They reportedly run high 13s, stock. Your thoughts? Last edited by 6130; 04-03-2018 at 02:45 AM. |
Liked 1,436 Times in 299 Posts
I don’t remember which exact year it was, but there was a local guy that ran the points meets occasionally at Cordova and Earlville that could go a second under. I think it had the mopar perf ecm and slicks. Add a lineloc and you are good to go. Not sure how long they can take the abuse stock, but I would think you could make most any solid used one run the index with some tweaking. Good news is that they are all stickshift I believe. Probably the only reason there are not more of them racing
Here is qualifying for Earlville with chuck blossoms entry inAF/s. I am sure Chuck flogged his a bit, but I know the other guy was not sciences out and still was fast. I know chuck passed away. Maybe his car is for sale? https://www.dragracecentral.com/DRCStory.asp?ID=145185
James Schaechter 3163 STK Last edited by james schaechter; 04-03-2018 at 05:56 AM. |
Liked 26 Times in 4 Posts
Remember a red neon SRT-4 that was driven several times to the Earlville Divisional & qualified well. The owner would camp beside it at the track. Told me he worked as a concrete finisher.
Bill Mitchell 5540 |
Liked 53 Times in 25 Posts
Jim Wahl had one so did Charlie Blossom but he pasted away.
Dennis P Chapman 1904 STK NHRA National Record Holder Car Owner. |
Liked 130 Times in 42 Posts
Wasn't that the same combo in Charlie's wife's PT cruiser he also raced time to time? It was fast.
The '05 isn't listed in the classification guide, and there are different engine specs for the '03 and '04 car.
I'm just spit-balling here, but I'm guessing if you swapped the front tires for the shortest slicks or autocross tires that will fit, along with removing the spare tire, jack, lug wrench, trunk mat, floor mats, and exhaust system, you'd probably be under the 13.50 AA/FS index, on pump gas, even if it was still overweight. But it might be a challenge to go rounds with three pedals and an H-pattern shift. Are there any auto-trans cars that are similar to these things? I probably wouldn't want a PT Cruiser. |
Don`t forget that you would have to run a NHRA approved race fuel, does NHRA have any unleaded fuel on the list? Would a car like that also need to have a SFI dated clutch assembly, if it is a stick car?
vp-c 10
Don`t go with auto cross tires. Use only a drag type tire. We found that out the hard way a few yeas ago.
Lane Weber It`s Not What You Drive That Wins....It`s How You Drive It |
That would be a driver problem , not a car problem. ;-)
