Liked 50 Times in 23 Posts
New CP custom pistons, for N351 Sportsman heads
4.080 bore Flat Tops Lateral Gas ports .043, .043, 3mm ring package 1.325 Compression height .927 pins Complete Package includes wrist pins and ring set All New in Original box. $550 shipped paypal ok New In Box CP custom pistons for N351 Sportsman heads 4.045 bore Flat Top Pistons Lateral Gas Ports .043, .043, 3mm ring grooves 1.250 compression height .927 wrist pins included ring set not included $400 Shipped paypal OK PM For Photos
Steve Stickel 1161 Stk 1167 SS |
Steve; what rod, stroke combo were you working with on the 4.045, 1.250 set of pistons? Thanks Much Larry
Larry,
You can create 10 12 combos with the 1.250 CH . 8.2 or 9.5 block, from a 308 to a Big Inch 351 (408)Stroker.. These pistons were popular in circle track. however, customers plan was 3.25 stroke, 8.2 block, Rod Length / 5.315 in. = 335 cu in PM for more details Hope this helps,
Steve Stickel 1161 Stk 1167 SS Last edited by Steve Stickel; 03-31-2018 at 08:01 PM. Reason: spelling |
