Old 02-20-2018, 10:59 PM   #1
rob7181
Default Base line setup for 8.90’s
Ok, please don’t crash into one another trying to follow me up for first round this year! But I am gonna put my big toe in the SC shark infested waters of D1 this season! The car is a 2014 dual shock Miller, 2050lbs race ready , 1180hp 598, 1250 max speed.
What starting line RPM, on stop time , off stop time and cruise rpm should I start out with?
rob7181 is offline   Reply With Quote
Old 02-21-2018, 10:18 AM   #2
Marc
Marc's Avatar
Liked 10 Times in 2 Posts
Default Re: Base line setup for 8.90’s
I have nowhere near the experience or knowledge to give sound advice (not to mention I run a different class and combo), but I will say that my initial settings haven't varied a whole lot since my first pass on the stop: .15 first timer, .35 shift (was .65, but picked up a bit of MPH with the earlier shift) and anywhere between 2.55 and 3.00 stop time depending on track, weather and opponent. Cruise RPM 4200.
Best of luck to you. You might want to consider running the Mid-Atlantic .90 Series in addition to the Divisionals. Great group of racers and with 2 races per weekend, you can get a lot of seat time.
Marc is offline   Reply With Quote
Old 02-21-2018, 04:02 PM   #3
voltdr
Liked 100 Times in 51 Posts
That's probably a good starting point. Of course there are only another 1,453,798 other combos to try also. C'mon in the water is fine.............
Dan
Dan Foley
SC 4698
voltdr is offline   Reply With Quote
Old 02-21-2018, 04:27 PM   #4
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
My S/C setup is very abnormal so I can't give any direct advice, but I feel that this is a good general guide:
http://www.biondoracing.com/mm5/merc...=FAQs#throttle
S/ST 51
S/C 53
Old 02-22-2018, 02:10 AM   #5
BKSG1198
BKSG1198's Avatar
Hey Rob,
Would love for you to come play with us in the Mid Atlantic .90 Series. Like Marc said 2 races per weekend and you get a lot of seat time (At least 6 runs) and if you go out early you can sometimes run a few test shots to gain some data. Same shark invested waters and drivers in D1 so this would allow you to meet a few racers and we do a BBQ every Saturday Night to let everyone meet new people. We run at Cecil twice, Atco twice and Maple Grove once and 3 of the 5 events are the weekends before the NHRA rolls into town. The payouts are good and it might not be a Wally but, our trophies are pretty cool. If you want more info throw me a message.
Rob K.
PS - I know your on the e-mail list, just making a pitch to have you come play
Old 02-22-2018, 08:34 PM   #6
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
One good source of info would be APD since you listed a MaxSpeed carb as part of your combination. Those carbs can work great or not so great from what I have seen. A setup that throws you curveballs will quickly make you want to quit stop racing. No different than an unpredictable bracket car. The numbers given in an earlier post should be a real good starting point. A T&T day can help a lot.
Rich Biebel
S/C 1479
Stock 147R
Old 02-22-2018, 10:37 PM   #7
rob7181
Thanks for the info, keep it coming!
Rob,
I am planning to be at several of your races. Just bring lots of duct tape and Bondo for the guys wrecking to get beside me.
Rich,
The engine and converter were in my Davis Vette I ran in SG for a year until I sold it and bought the dragster. Have done some stop racing, just not SC in a dragster. Decided I am going to give the Camaro a go at 9.90’s and the dragster a shot in 8.90 this year.
Old 02-25-2018, 08:33 AM   #8
sst5167
sst5167's Avatar
Liked 17 Times in 9 Posts
There are so many little things that can go into a good throttle stop set up. And every car will be just a little different.
My wife's super comp car is lighter than most suspended cars, and also seems to react and launch more aggressively than most. So our set up is softer than most.
Suspended 235", 1070 HP, 1050 APD Max Speed carb
Timer 1- .01
Shift - .15
Timer 2- 2.50-2.75
Roll RPM 4000
Something else very important, that I rarely hear mentioned when talking about throttle stop set ups is opening and closing speeds of the stop. I have found the closing speed to be very critical for several reasons. If it closes to slow, you will have a very fast 60', which can be a little mph loss as well as it puts you out in front of the race to much. But more importantly, if it closes to fast, you will see a dip in the rpm on the stop.
sst5167 is offline   Reply With Quote
Old 03-14-2018, 11:17 AM   #9
Mbodnar
Mbodnar's Avatar
Liked 8 Times in 6 Posts
For a new driver in the .90 I would highly recommend attending some of Rob's and the Mid Atlantic .90 events. As a new driver last year I only attended one of the events, but I can assure you the extra seat time gave me a whole bunch of confidence for the next week of racing.
Class Racer Magazine Writer
Super Comp A197
Mbodnar is offline   Reply With Quote
