Old 02-20-2018, 12:25 PM   #41
Dwight Southerland
Dwight Southerland's Avatar
Liked 784 Times in 196 Posts
Default Re: Titanium Valves in SS
Originally Posted by BBF67 View Post
Correct starting in 1967 with no penalty. Prior to that the GM or 401 aluminum head gets the horsepower penalty.
Where does the class guide show the 396 Corvette with a natural class of SS/C?
According to the class guide, the P/W factor is 7.65. That is SS/D.
The confusion may have started because of the two different methods to determine class when replacement heads are given a different power rating.
Method 1: If you say that the calculation is based on shipping weight, then the classification for the aluminum head is calculated by the different power rating divided into the shipping weight and results in a new P/W factor not listed in the Class Guide. (65 Corvette 396 shipping weight is 3022 lb / 411 = 7.35 or SS/C. The car can run in SS/B, C or D. This may be how Jimmy is getting the car classified in SS/B.)
Method 2: If you say the calculation is based on the P/W factor listed in the Class Guide, then the classifications stay the same as indicated in the Class Guide, but the weight changes. (65 Corvette 396 P/W factor is 7.65 SS/D so it runs SS/C, D or E. The minimum weights for the classes is based on the power factor with aluminum heads aluminum heads.).
I have had this ongoing conversation with people from NHRA tech for several years and the opinion/answer changes. The last statement from them was number 2.
Dwight Southerland is online now   Reply With Quote
Old 02-20-2018, 01:02 PM   #42
fredjohnston
Liked 55 Times in 14 Posts
Dwight - with all due respect, there is only one method and that's to look at what it says in the NHRA classification guide, see that it says 7.65 @ 411 and to abide by it. No need for a calculator.
Now if anyone feels the 7.65 was put in the guide by error, then take it up with NHRA and hash it out. In the mean time, this combo should be raced at 7.65 with a HP rating of 411.
fredjohnston is offline   Reply With Quote
Old 02-20-2018, 01:42 PM   #43
Race Clean
Liked 129 Times in 53 Posts
I bet if it had been another make the tune would be different..
Race Clean is offline   Reply With Quote
Old 02-20-2018, 06:35 PM   #44
Dwight Southerland
As I said, I have been having this conversation with a variety of people at NHRA Tech for a long time and the method/opinion has changed back and forth depending when and who you talk to. I agree that the current consensus is to use the P/W factor found in the Class Guide to determine the class, and use the power factor to multiply to find the race weight.
It has not always been that way.
Old 02-20-2018, 07:32 PM   #45
Andrew Hill
Andrew Hill's Avatar
Liked 174 Times in 39 Posts
Straight from the rule book, "The power-to-weight factor is the shipping weight of the vehicle divided by the advertised, or when applicable, the factored horsepower for the OEM-assembly-line cylinder heads. NHRA-accepted aftermarket cylinder heads carry a horsepower penalty that is calculated to the weight of the vehicle and does not change the class of the vehicle."
I'm not sure when this verbiage was added, but it's in the 2017 and 2018 rule books.
Edit: just realized this quote was already posted on the last page, oops.
3207 D/SA, C/ED
Andrew Hill is online now   Reply With Quote
Old 02-22-2018, 08:32 PM   #46
bkraft
Liked 15 Times in 6 Posts
I'm all about rules, but this is getting mighty expensive!
Name:	broke valve 1.JPG
ID:	44066   Click image for larger version
Name:	broke valve 2.JPG
ID:	44067   Click image for larger version
Name:	broke valve 3.JPG
bkraft is offline   Reply With Quote
Old 02-23-2018, 12:34 AM   #47
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
I would be all in for the option of running titanium valves. I change both intake and exhaust after every season. Blowups like the above pics keeps me awake at night.
Old 02-23-2018, 01:13 AM   #48
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
The 5/16ths stems on the Hemi valves is definitely scary. A broken engine in the traps with a 68 race Hemi running close to 160 mph could cost a life. A diaper can hold some of the oil but a 4 spd car could lock up the wheels almost instantly. At that speed it only takes a second to get a car out of shape.
Old 02-23-2018, 04:47 PM   #49
Jim Hanig
Liked 99 Times in 49 Posts
You wouldn't change them if you could use titanium?
Old 02-23-2018, 07:40 PM   #50
Spyphish
Liked 679 Times in 180 Posts
Dyno, if you are going to hang around with WALDO, don't stay up at night. All my KABOOMs were self inflicted. Two step unhooked, throwout bearing too long. Yata Yata BUT it would be nice to get the steering out of the motor, kind'a like the new cars which go as fast or faster. Had to fill out NHRA oil down sheet after Indy, "kind'a hard to pull over with a connecting rod jammed on your drag link."
Had to use a bigazz hammer to get it off. This is Holt's stuff, which use to fit perfect. Jane wants me out so we will see. That draglink tube intrusion happens in the traps, ya'll could have had a RIP thread. ME3
ID:	44071   Click image for larger version
ID:	44072   Click image for larger version
