Old 01-31-2018, 02:02 PM   #1
STR001
Default Thrd Gen Camaro Recommendation
Trying to determine which year and body style Camaro would be best for a carbureted small based cam 305. I personally like the Camaros with the ground effects. But, is there an advantage claiming the Camaro as a sport coupe over the Z-28 model for example? Any advice would be greatly appreciated. Jason Tucker
STR001 is offline   Reply With Quote
Old 01-31-2018, 02:42 PM   #2
Liked 10,763 Times in 2,237 Posts
Default Re: Thrd Gen Camaro Recommendation
How many pounds of fruit cake is the answer worth?
Old 01-31-2018, 05:54 PM   #3
jmcarter
jmcarter's Avatar
For the un-enlightened, Jason lists his hometown as Claxton GA. Known around these parts at least for fruit cake. Makes for good ballast after sitting around for a few months too.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 01-31-2018, 06:26 PM   #4
Jason, Your best bet here is to tell us the exact combo and class you want to run, and where.
We'll pick it apart from there. LOL
Oh, and send me a nut assortment instead at Christmas time.
I don't even know what that stuff is in fruitcakes.
Old 01-31-2018, 06:54 PM   #5
REGGIE WINKLES
Liked 39 Times in 9 Posts
Jason, my deal is the small cam/dished 150/244 combo. With the 84 Z/28 trim it's a natural J car, I prefer the extra weight and usually run in K. This engine combo is available for the 82-84 F-body.
The 85 & up small cam/ flat top engine is also an option, I think it fits in I or J. If I had it to do over I would go with the big cam/flat top setup. My 2 cents worth!
Reggie Winkles 2650/Stock
REGGIE WINKLES is offline   Reply With Quote
Old 01-31-2018, 07:21 PM   #6
I believe that fruitcake possesses a certain growth hormone.
Old 01-31-2018, 11:57 PM   #7
STR001
Guys, this is supposed to be the 305/150 small cam, flat top piston motor which I think is for the 85 Camaro. Does it matter if I use a sport coupe Camaro vs. the z-28 style with the ground effects? Is there an advantage to using one over the other?
BTW, never been a big fan of the fruitcake but somebody must like it based on the size of the houses these owners live in that makes the stuff. I think using it as ballast is an excellent idea! Jason
Old 02-01-2018, 01:01 AM   #8
MR DERBY CITY
Liked 7,992 Times in 1,525 Posts
The answer to your question can be found in the stock classification guide under NHRA competition.....the sport coupe 85 model is a natural H car while the Berlinetta with auto ,Z28 ,and IROC are all natural I cars.....
Old 02-01-2018, 09:33 AM   #9
terry1
Liked 24 Times in 13 Posts
Smile Re: Thrd Gen Camaro Recommendation
The weight break of the Z28 over the "coupe" is similar to the
late 70's Z(heavier ) compared to the "coupe". The Z is natural J, where the
"coupe" is a natural I.
Terry K
terry1 is offline   Reply With Quote
Old 02-01-2018, 10:12 AM   #10
stock1080
Liked 94 Times in 38 Posts
also if your running a stick or autoooooooooooooooooooomatic...
stock1080 is offline   Reply With Quote
