Go Back   CLASS RACER FORUM > Class Racer Forums > Competition Tech
Old 01-25-2018, 03:09 AM   #1
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Pin On Hood Fasteners
Originally Posted by Hacksaw View Post
Think some fasteners are not accepted by NHRA. Wonder about two large hood pin styles, similar to the Quik- Latch style?
I can't find restrictions on fasteners in the 2017 rule book but that dosen't mean they don't exist...
I'm thinking 8 fasteners. Three on each side and two across the front. Cost will determine the exact style. A flat hood and T Bolt blister will run me around $550.
Dale Shearon
68 Mustang 6394
Old 01-25-2018, 11:26 AM   #2
Mark Ugrich
Liked 71 Times in 38 Posts
Another option would be to use 1”x1” aluminum angle. Run it through a Shrinker / stretcher so it conforms to the fender contours. Fabricate two brackets for the front, and add fasteners of your choice.
Old 01-26-2018, 11:35 PM   #3
SSDiv6
Liked 1,578 Times in 581 Posts
Dale,
Do you have aluminum or cast iron cylinder heads?
SS/CS is a cast iron cylinder head class on;y; no aluminum.
Old 01-28-2018, 02:28 AM   #4
FireSale
FireSale's Avatar
Dale,
Cast. Iron. In-Line. N351 with a Ford part number. Not on any list but they are on the NHRA 1/8 mile record holder over in D3. Perno is the guy's name. I also talked to Mike Delahanty about these heads and he had no concerns. I'll find out. They are so heavy compared to my old AFR heads that I have had to use my engine hoist to get them in and out.
The flat glass hood might hood might not work. Not easy to find and quality is suspect. Lots of good 3 1/2 inch cowels so I'll probably keep light springs and hinges with extra pins and no latch.
Dale Shearon
68 Mustang 6394
Old 01-30-2018, 01:29 PM   #5
Tim Kish
Liked 11 Times in 4 Posts
A lift off hood sucks in Super Stock from the standpoint of having to remove it for fuel check. You are down there by yourself, if it's windy you don't want it sitting up on the roof unattended. Mine won't sit on the roof so I have to find a spot in the grass to set it. Make the hood hinged it at all possible.
Tim Kish
3032 SS/GS
Tim Kish is offline   Reply With Quote
Old 01-31-2018, 12:48 AM   #6
FireSale
FireSale's Avatar
I wound up ordering a better quality cowl hood from California Mustang. Truck freight up to Washington will be a bit better than a flat hood from Florida. It's reinforced for a hinge with light springs so it will be more serviceable. Still going to have Dzuts style fasteners instead of a latch. One on each side and two on the front.
Thanks for all the input.
Dale Shearon
68 Mustang 6394
