Old 01-22-2018, 02:14 PM   #1
James L Miller
Liked 25 Times in 16 Posts
Default Robert Ray Welding in Indiana
Anyone have contact info for Robert Ray welding in Seymour, Indiana? My engine guy is looking for someone experienced in welding cast iron blocks and heads. Thanks.
Mopar 2 Ya!
Old 01-22-2018, 02:35 PM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: Robert Ray Welding in Indiana
check your PM's---FED 387
Old 01-23-2018, 12:10 AM   #3
Kevin Panzino
Kevin Panzino's Avatar
Liked 748 Times in 137 Posts
Ray's Cracked Head Service
7030 E County Road 1000 N
Seymour, Indiana 47274
Phone (812) 522-7036
Old 01-23-2018, 09:23 AM   #4
Liked 10,762 Times in 2,237 Posts
Indy Cylinder head did cast welding with a cast filler rod. They might do blocks.
Old 01-23-2018, 09:15 PM   #5
James L Miller
Thanks for the info. Does Indy do their own welding, or do they send it to Rays?
Mopar 2 Ya!
Old 01-24-2018, 09:01 AM   #6
When I saw it done it was in house. I thought it was art-form.
Old 01-24-2018, 01:56 PM   #7
340Cuda
Liked 804 Times in 341 Posts
I am not sure but I think Ray may have been the guy that used to work for Indy and do heads and blocks in house.
Old 01-24-2018, 03:12 PM   #8
Todd Gross
Liked 54 Times in 24 Posts
There is also Tri-state cylinder Head in Evansville that does furnace cast iron welding
Todd Gross
3323 FS/E,F
Todd Gross is offline   Reply With Quote
Old 01-25-2018, 05:59 PM   #9
Dissident
Liked 73 Times in 36 Posts
Folks interested in this kind of stuff -
Well, this place is not located in Indiana but........
One of the best kept secret places that welds cast iron parts is located in Cambridge, IA. Schell Welding (515)383-4830.
Their work is not only impressive, it is done so well, one cannot see where the welding was done (after machining). Now that the kitty is out of the bag, the rest is on you.
Good Luck as you think with creativity.
Dissident
Dissident is offline   Reply With Quote
Old 01-25-2018, 11:35 PM   #10
James L Miller
Thanks for the additional resources. It seems they are all in the Indiana/Iowa area. My guy used Al Mathon for years. His son didn't want to continue the welding shop from what I was told. One of his customers blew the bottom out of a Turbo Buick V6 by swapping computers and not checking the timing. Cracked the main webs, bent the pins, cracked the Bryant crank, etc.
Mopar 2 Ya!
