Liked 112 Times in 31 Posts
Chad I think you nailed it right on the head there. Both with the newer stand alone fuel systems and with NHRA's ability to check and enforce the car. It would probably still be a pretty good combo.
Rick |
Unless their is something additional in the tech manual that isn't published, the specs listed in the blueprints are housing size, number of compressor impeller blades, and compressor inducer diameter. I think stock appearing externally goes without saying, but that leaves A LOT of grey area in that turbo, probably 100hp worth
Chad Rhodes 2113 I/SA |
Liked 323 Times in 63 Posts
When I was running a turbo Buick NHRA made me remove the turbo an disassemble it.
They had all the internal specs. This was in teardown at a national event.
Bob Shaw V/SA 515 |
but how long ago was that? and why wouldn't they publish that information.
Liked 56 Times in 21 Posts
i am with Bob
nhra did the same to me they have things that are not in the books and i try to get them but it was a NO i had no trouble with boost 15# on the line and 30 in the traps stock tubro
Vic Guilmino 1129 STK |
Liked 3,249 Times in 988 Posts
Perhaps after Ingersoll turned the Pro Stock ranks on their ear?
Both the non intercooled and intercooled combos were horsepowered by non stock turbos. Nhra had no idea what to look for and thought a stage 3 turbo was stock. Apparently Dave Shultz before he died had schooled NHRA on turbos. After that they had all the turbo cars in the barns. The Gallina's were the only ones that ran a motec engine management system that was incredible. Now there are really good systems out that would help the "drivability". Plus dual calipers. That engine would have to make 450hp to be fast and at 30 pounds of boost it could be done once or twice.
No prep is king |
