Unless their is something additional in the tech manual that isn't published, the specs listed in the blueprints are housing size, number of compressor impeller blades, and compressor inducer diameter. I think stock appearing externally goes without saying, but that leaves A LOT of grey area in that turbo, probably 100hp worth
Chad Rhodes 2113 I/SA |
#2 | |
Liked 1,952 Times in 439 Posts
Even nearly 20 years ago, we solved the staging/turbo boost problem. You have to have the correct converter, with the ability to "free stall", while creating load to build boost, and with good torque multiplication to launch the car. An ATI 8" Treemaster MRT, that Jim Beattie built for me, Charlie Plott sold it to me, was the first one to work right. When we put it in the car, the customer was pissed off, because "it takes a year to build boost". Well, he had put it in the car the day before the race, and never tuned it. The Monday after the race, he went home, and started tuning. When he trashed the "usual tune" of the day, which had no timing advance to speak of ("you can't put timing in it while you're trying to stage and build boost, it will detonate, and blow the pistons and head gaskets out", or so everyone said) and dumped raw fuel in it ("you gotta throw fuel at it, it needs fuel to make boost and power, it will lean out and melt any higher than 7:1 A/F-R") and started actually tuning it, he found that with decent advance, and an A/F-R of around 11-12:1, it would build boost so quick and easy that it was hard to hold in the lights. Without killer brakes, and a stout left leg, it was nearly impossible. He had to go back and get much better tires, put better brakes on the car, and get real deep in the suspension. After tuning, he was literally pre staging, then getting on the converter, and as he bumped into the stage beam, it would go from 2 psi to 16 psi, blow the rear tires off and roll the beam before the tree came on.
Alan Roehrich 212A G/S |
Liked 2,783 Times in 981 Posts
Freddie Vetter's GN was bad fast, our car and his qualified in the top sixteen at the Keystones one year and we both went to the barn, except he didn't want to take his car apart because he didn't know how to put it back together, so he took the DQ and went home, probably to play golf. He was a great guy, but not too good with tools. He used to keep his golf clubs in his truck just in case.
Liked 56 Times in 21 Posts
Frank what year was that
i think he had the front mount intercooler on the car
Vic Guilmino 1129 STK |
