Liked 189 Times in 48 Posts
Used
350/300hp - apart - all in good shape - engine had about 100 total passes on it. Bow Tie Block w/ billet splayed caps GM steel crank - lightened Manley Rods (standard journal) BME pistons Comp cams cam & lifters Jesel belt drive and rocker arms Gulius cylinder heads and intake Complete manifold to pan A good reliable consistent combo Get it honed and reassemble $ 8500 obo Brand New 350 - L-98 EFI Complete Engine ready to go Gulius built - same combo that Qualified #1 at the Dutch. all the best parts / all brand new (including the block) Bow Tie Block / .904 Crower Maximus Lifters / 55mm Cam Jesel Belt Drive & Rockers / ATI Balancer Custom Crank - Manley/Honda Rods BME Gas-Ported Pistons HRE Intake Manifold Iron head / 270 nhra hp factor #083 heads - test run prior to building the engine - NO LEAKS Very versatile combo - fits many classes - Injection programming and tune up info included Complete EFI systems available if needed Price lowered to $25,000
Angelo DiTocco '98 Firebird SS/HA '98 Firebird B/SA Last edited by Angelo DiTocco; 04-30-2018 at 05:19 PM. |
Liked 1,943 Times in 584 Posts
Hi Angelo
I have a few questions on the used 350? What head number and valve size? Is this a flat top piston combo? Is this the same as the 295/313 combo for a 67/68 Camaro? Thanks!!
Mike Pearson 2485 SS |
#3 | |
1.94 valve Yes flat-top piston And yes - it's the 313hp in SS
Angelo DiTocco '98 Firebird SS/HA '98 Firebird B/SA |
Can you send me some pics of the engine parts and your contact info. Send to ssia2485@yahoo.com or text to 813-433-4742.
Thanks
Will do
