Old 11-04-2017, 11:18 AM   #1
Andys dad
Andys dad's Avatar
Liked 175 Times in 78 Posts
Default Re: 426 Hemi Display Engine
Originally Posted by John Duzac View Post
I need some help with a project I am currently putting together. A close friend wants me to build a 426 Hemi Display engine for his car collection. I am looking for the following engine parts:
I need a 426 Hemi Block. This Block can be destroyed internally, as it will never run again. No pistons, rods or any internal part will be installed.
I need a crank shaft. I’m told a 440 crank will work?
I would like to find an old cross ram intake manifold which can be fitted with new carbs. That’s about the only thing on this Display engine that will be functional.
I have tentatively located a set of crashed heads from a SS/AH racer. Again, no one will ever look at the technology of another racer. This I promise!
I need Stock type valve covers. Spark plug tubes.
I have a stock oil pan, timing cover, oil pump and water pump.
Any help on the above listed parts will be appreciated. I’m not trying to get these parts for nothing.
John Duzac
504-259-5935
Bob Lambeck has older hemi parts his # is 208-250-8005
Old 11-04-2017, 12:10 PM   #2
Albert Lee
Liked 258 Times in 49 Posts
Long ago I planned the same thing but have since abandoned the project. I have a block, crank, piston, rods, and heads. All cheap! Will separate.
Al Corda 612.963.4540 text/cell - NO pm's please
Albert Lee is offline   Reply With Quote
