#17 |
When possible and if available, use a control cable that has a Teflon liner and lubrication will not be required.
Also, make sure the control cable is not exposed to excessive heat. Excessive heat will dry out the lubricant or deteriorate the cable. If the control cable does not have a Teflon liner, lubricate with a spray lube designed for open chains that contains Moly Disulfide. One great lubricant is ACF-50 Anti-Corrosion Lubricant. |
